Maya 2017 stops working every few mins
ys.kuzi
Message 1 of 13
ys.kuzi
hi my Maya 2017 just will not work while I animate or do anything else I used the 2016.5 and that is working just fine my college is teaching with Maya 2017 and I am getting left out cuz many of those things I just don't have
plz help me out
my output screen just goes mad whenever Maya stops working
Stack trace:
  MSVCR110.dll!memmove
  Foundation.dll!Tarray::insertElement
  KinSlice.dll!TikHandle::joints
  KinSlice.dll!TikHandleGroup::getJoints
  KinSlice.dll!TikSystem::getAffectedBySolve
  KinSlice.dll!TikSystem::doSolve
  KinSlice.dll!TikSystem::startSolve
  KinSlice.dll!TikHandle::triggerIK
  KinSlice.dll!TikHandle::matrix
  DataModel.dll!Ttransform::pathMatrix
  DataModel.dll!TdagPath::inclusiveMatrix
  DataModel.dll!TdagObject::putMatrixInBlock
  DataModel.dll!TdagObject::computePlug
  DataModel.dll!Ttransform::computePlug
  KinSlice.dll!TikHandle::computePlug
  DependEngine.dll!TevaluationNode::evaluateDirtyPlugs
  DependEngine.dll!TevaluationNode::taskEvaluation
  DependEngine.dll!TevaluationTransparentClusterNode::taskEvaluationOpaque
  tbb.dll!tbb::interface7::internal::task_arena_base::internal_execute
  DependEngine.dll!TexecutionNode::schedulingNodeReset
  tbb.dll!tbb::interface7::internal::task_arena_base::internal_initialize
  tbb.dll!tbb::task_scheduler_init::initialize
  tbb.dll!tbb::internal::thread_sleep_v3
  MSVCR110.dll!_beginthreadex
  MSVCR110.dll!_endthreadex
  KERNEL32.DLL!BaseThreadInitThunk
  ntdll.dll!RtlUserThreadStart
this is what I get
please help
system spec
2x gtx 980ti
intel Xeon e5 1650 v3
32 gb ecc ram
please help
Replies (12)
Message 2 of 13
NandoStille
Just some ideas to sort things out:
1. Maya 2017 Update 2 installed?
2. Latest graphics card drivers?
3. Is this happening with default prefs too?
4. Is this happening with "DG" evaluation mode (prefs / animation / evaluation mode)?
If yes, try to set to "Parallel" and turn "GPU Override" off. Is this still working then?
Message 3 of 13
ys.kuzi
Latest Nvidia drivers
Download maya again yesterday
Yes this is on default
And i tried not using gpu for maya and just tried using parallel
Is there an other way to update maya??
I am on the students edition
Message 4 of 13
ys.kuzi
Message 5 of 13
ys.kuzi
This is a blank
Message 6 of 13
ys.kuzi
Do i have to download maya update 2 from somewhere else
Cuz I downloaded maya clean again today it still does not work
Yeah newest Nvidia drivers but for some reason in the output window it always says that Nvidia drivers not found
Yes its happening in default prefs
I really don't know what is 'DG' evaluation
I did turn gpu override off to check stil was not working
Message 7 of 13
Try update 1, U2 is full of bugs!
Message 8 of 13
ys.kuzi
How to do that i really don't know much about this and thank you if this works my life will be too good
Message 9 of 13
NandoStille
In Maya check the "About" entry in the "Help" menu. It shows what version you are using.
You should really have at least Update1 installed. I think I had this problem too in the beginning and the Update fixed it aside from quite a number of other issues. As pointed out, Update 2 brought new issues. So just try Update 1 first.
Did you check your Autodesk Account for the Updates? Look for the Maya 2017 entry. There in "Downloads" you should find an "Updates & Addons" section.
The "DG" evaluation mode is the legacy mode to evaluate the graph. Actually you should not be needed to use it anymore with your hardware, but if nothing else works, it might be interesting to see if it does anything.
Message 10 of 13
ys.kuzi
I am trying to make it wok then Arnold stops working or just is not seen anymore
yes i was using update two now moving to update one
Message 11 of 13
ys.kuzi
i did do that but even now it crashes as soon as i open my file to work on and i am unable to do anything i mean just rotating kills Maya
Message 12 of 13
ys.kuzi
Initialized VP2.0 renderer {
Version : 2016.3.31.11. Feature Level 5.
Adapter : GeForce GTX 980 Ti/PCIe/SSE2
Vendor ID: 4318. Device ID : 6088
Driver : .
API : OpenGL V.4.5.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 6144 MB.
CPU Memory Limit: 31058.8 MB.
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
0: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 8.0.0.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
Choosing OpenCL Device GeForce GTX 980 Ti. Device Type: GPU Device is available.
Stack trace:
this is all i get in my output window and Maya does not work anymore
i took a screen shot the scene is not heavy at all still
Message 13 of 13
NandoStille
I fear it's the same bug as this one:
http://forums.autodesk.com/t5/maya-forum/severe-freezing-maya-2017/td-p/6687498
Only other thing you can try is to switch the Default Viewport in Prefs/Display to Legacy or/and make sure the Renderer in all Views is set to Legacy.
