Maya 2017 preferences won't save!!
Message 1 of 20
I am using the Maya 2017 student version, and my preferences won't save. I have tried over and over again, even created a new workspace. Nothing seems to work.
Even my shelf Icons won't save.
It is getting really annoying having to set up my preferences every time I open up Maya. I hit save preferences and get this warning in my script editor. https://imgur.com/Aa9O4hO
If anyone knows a way to fix this issue, I would really appreciate it.
Thank you.
Hi @Anonymous your title 'HELP- My Maya preferences won't save!!' was edited for clarity by @sean.heasley
Replies (19)
Message 2 of 20
sean.heasley
Hi @Anonymous and welcome to the community!
It looks like there may be an issue with admin controls. Are you an admin on your machine? If not can you become one and or have the admin change your settings so they dont interfere with Maya?
There was also a similar issue in this thread that may be helpful to you!
Please let me know if this information is helpful or if anything changes!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 3 of 20
Hello Sean,
Yes I am running Maya as Admin. but I still get that warning in the script editor.
Message 4 of 20
sean.heasley
Hi @Anonymous
It looks to me like you might have an environment variable set that is point your preferences to the 😧 drive:
D://maya/2017-x64/prefs/shelves/shelf_XGen
Two places to check if this is set, first place is your system variables:
  1. Go to Start > Run > type control sysdm.cpl and click OK.
  2. This will bring up the System Properties window.
  3. Go to the Advanced tab.
  4. Click on Environment Variables.
  5. Check to see if you have an environment variable that relates to MAYA.
  6. You may have like a MAYA_LOCATION or somthing to that extent.
  7. Check to see if it has a value of D://maya/2017-x64/prefs/ if it does I would recommend removing it as that is what is causing the warning.
The second place to look is in the Maya.env file:
  1. Go to C:\Users\santosd\Documents\maya\2017-x64
  2. Open Maya.env in notepad or another text editor.
  3. Check to see if you have any environment variables that are set to the D://maya/2017-x64/prefs/ drive and remove them.
I hope that this information is helpful but let me know if you need any more assistance!
Message 5 of 20
There was no Variable named Maya_Location or anything related to maya.
And my Maya.env file is empty, but i found it in my 😧 drive. Is that a problem?
I believe my Maya is installed in my C drive.
Message 6 of 20
sean.heasley
Hi @Anonymous
If you installed to your C drive but the env file got moved to the D drive somehow that could cause a program.
You could try copy/pasting the env file to the proper location but if that doesnt work for whatever reason you may want to
perform a clean uninstall/reinstall of Maya. This way you can remove every folder and file related to Maya and properly install
it on the right drive which should resolve your issue!
Please let me know if this information is helpful or if you need any more assistance!
Message 7 of 20
Thank you.
I tried the copy and paste method, and that didnt work.
So im reinstalling Maya now. I hope this works.
Message 8 of 20
Ok, I did a clean reinstall.
Some settings are saving, but i still get this in the script editor...  https://imgur.com/pZ0dbv5
I have no idea what to do, and frankly this is just getting annoying.
Message 9 of 20
sean.heasley
Hi @Anonymous
That's really unusual that its giving the same error after the clean uninstall/reinstall Smiley Frustrated
When you installed it, do you know which hard drive you chose to install Maya to?
Also, are you making any drastic changes to the prefs that could be causing the issue? Like using unsupported characters such as " . / ;"?
If not, can you please explain what changes, if any, you are trying to make to your prefs?
Please let me know when you get a chance!
Message 10 of 20
Yes, I installed in into my C drive, and maya documents are sent to my D Drive. Idk why.
And as far as changes to my prefs, they are  simple, just click auto key, change timeslider and animation settings. I think simple things. I haven't used any weird characters either. Some are saving, more than last time I guess. Even shelf items disappear every time I run Maya.
Thanks for the responses btw.
Message 11 of 20
sean.heasley
Hi @Anonymous
It sounds like the issue is with the documents being sent to the D drive because that is not how the install should work.
I understand how frustrating this can be, but is it possible you could perform another clean uninstall/reinstall and then try installing just to the D drive?
If you do this, the entirety of Maya should be installed to the D drive however your Documents folder on your C drive should be set up properly and you should be able to save your preferences!
Please let me know if this solves your issue otherwise I'll be happy to continue working with you further!
Message 12 of 20
I will try that. But for the sake of me getting some work done, I will do it over the weekend.
I hope it helps, and I appreciate the help.
Thank you.
Message 13 of 20
sean.heasley
Okay @Anonymous sounds good!
I'll be sure to keep this thread on my radar and I'll check in with you in a few days to see how it goes!
Message 14 of 20
RFlannery1
I know you said you already checked your environment variables and there was nothing Maya related.  For what it's worth, the environment variable you would be looking for would be MAYA_APP_DIR.  In my case, Maya is installed on the C: drive, but I wanted my preferences saved on the U: drive.  So I set MAYA_APP_DIR to U:\maya.
You can check from within Maya whether this environment variable is set.
  1. Find the command line.  It is usually in the lower left of the Maya main window.  https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Maya/fil...
  2. If it says "MEL" on the left side, click on that text to change it to "Python".
  3. Type "import os" and press enter.
  4. Type "os.getenv('MAYA_APP_DIR')" and press enter.  Capitalization is important!
  5. If then environment variable is set, you a result will appear with the path it is set to.
Unfortunately, what this can't tell you is where the variable is set.  Is it set in the system environment variables?  Is it set in Maya.env?  Who knows?  (Although the following article seems to suggest it can't be set in Maya.env.  https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Maya/fil...)
Message 15 of 20
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did you get a chance to try the suggestions I posted over the weekend? Did they help solve your issue at all?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 16 of 20
Thank you very much for the help. I did do another clean re install and some preferences are saving, but I still get this error. https://imgur.com/r8HjrUs
Seems shelf Icons don't save either.
Message 17 of 20
sean.heasley
Hi @Anonymous
Did you get a chance to try the steps @RFlannery1 provided?
Also I noticed it still says your preferences are on your D drive while the rest of Maya is on your C drive?
Were you sure to install Maya on one hard drive and not both?
Let me know if anything changes!
Message 18 of 20
sean.heasley
Hi @Anonymous
I'm sure you've been busy but I just wanted to see if you're still having this issue with your preferences not saving. Did you get a chance to try the steps @RFlannery1 provided?
If your issues is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 19 of 20
Thank you very much! It is running a lot better, just a few tweaks on start up, which is better than 10 to 12 tweaks. I can mark this as Solution.
Thank you again.
Message 20 of 20
//Warning: line 1: Not all preferences were saved. See script editor for details.//
sorry for bothering I use Maya 2019 and every time I open Maya I have to put my shortcuts again and it does not allow me to save my workspace. A text appears in the script window that says:    //Warning: line 1: Not all preferences were saved. See script editor for details.//     Any help would be great.   Thanks
