I do not have any third party plug ins installed. I am still having the same issues even after un installing and re installing. Maya crashing the moment i press "plug in manager". I am also getting this bit in the script editor upon start up, not sure if its related:
"onSetCurrentLayout "Maya Classic";
file -f -new;
preferredRenderer -makeCurrent;
// Warning: file: C:/Program Files/Autodesk/Maya2017/scripts/startup/rememberViewportSettings.mel line 29: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
// untitled //
commandPort -securityWarning -name commandportDefault;
// Error: file: C:/Program Files/Autodesk/Maya2017/scripts/startup/autoLoadPlugin.mel line 32: Plug-in, "Mayatomr", was not found on MAYA_PLUG_IN_PATH. //
// AbcExport v1.0 using Alembic 1.5.8 (built Dec 24 2015 17:28:19) //
// AbcImport v1.0 using Alembic 1.5.8 (built Dec 24 2015 17:28:19) //
// Error: moduleInfo -d -mn " ¥ˆÉµ"DcÛ *N<ÑâÎ4’N܈Õþç¦WÂr ŽAZh Z+C<`þ¡ÍÖ„ ~M ¢ŒU“Œ¬„Ìq¥Ä%M<,zÚ[ÀgЉ ¼ éR"; //
// Error: Line 1.30: Syntax error //
// Error: moduleInfo -d -mn " •’[D çVôÇè ÒôƒÛ»ö” ³® ÷‰XÑ’Îéì„s~ œ ZŠÄr0ƒZòi y"òAÎÝñ’Vz¨š"; //
// Error: Line 1.75: Syntax error //
// Error: moduleInfo -d -mn " " † N¥"; //
// Error: Line 1.22: Syntax error //
// Error: line 1: No module definition file found //
// Error: moduleInfo -d -mn " È_ p¤W{áWÐîâ ó7~Ù§ §¶ +OØMÞ *•÷ ä“-hÿ ¬'O+îÉ¿¶"7µê 1‹ÉCº ØJ±œ] ³"; //
// Error: Line 1.69: Syntax error //
// Error: moduleInfo -d -mn """; //
// Error: Line 1.23: Unterminated string. //
// Error: moduleInfo -d -mn "" ,aä "; //
// Error: Line 1.21: Syntax error //
// Error: moduleInfo -d -mn "#Ÿ x¥í”–+g Œ m|‰Ó[¤]1wH¸G|"; //
// Error: Line 1.29: Unterminated string. //
// Error: moduleInfo -d -mn "$ Á\ á)‡¹Ñ 8\þ ç ‡s7 wÞ ’GÞÐ Òàl—‚Þ ‘ ¢ˆF"; //
// Error: Line 1.56: Unterminated string. //
// Error: moduleInfo -d -mn "6ùý í4^ãU¶Ã›žÈæÊ¨i^åâüüg"* ¿-y$kó×cé3Éð+Äý› Áa/… "; //
// Error: Line 1.45: Syntax error //
// Error: moduleInfo -d -mn "WŠx÷ˆêŽNÝ%êMdnãø‘rž% ™" i ‰ÌßÑùöÁ Tµf ÿüö]´8Ÿª@$¢' ´§½£Œb¤ýº‡ŠÖ¶+R<RDî ‘ Š]ÛùØXM; kŽ:æ •û©÷Þ¹¥€ê$ éhßùi˜ªù#€ //
// Error: Line 1.43: Syntax error //
// Error: moduleInfo -d -mn "_ÚH⿈ „¢ …7"yÂm†bøÇ 5 ÑüXß` ÙÒž” Š`°´‘ÊKarBÁ`Ü D~LBÄ"; //
// Error: Line 1.36: Syntax error //
// Error: moduleInfo -d -mn "`/!O[h*TŸ O @ Õ½xÊÁ?3Тš4ì÷K‰ ‹x…5Ê’ pXŠí,ËGž² z¬@'b¦â oD´ !ù©Ñ¢âq³Ÿ*WߌÂp4n½ æ"š8œ¹œM ¶\† /_›:¯{÷´^þ J2áA€ //
// Error: Line 1.102: Syntax error //
// Error: moduleInfo -d -mn "bÿÝ[(ß^|ßaøáµï! ú[ÌÓÇ*¹s ×ä i8³9 Šóå’nM c¯¿( "; //
// Error: Line 1.43: Unterminated string. //
// Error: moduleInfo -d -mn "c<»"žíF-´žZI ê艃âx>ãå‚Ü߯#â©'šƒ<àxùÇO7”Ò( ~¸“ô—’ŠøèBS"; //
// Error: Line 1.24: Syntax error //
// Error: moduleInfo -d -mn "‘Ùè =¢Gôˆ Ñ#zD è =" % ÿ9»b9' ¼:"; //
// Error: Line 1.39: Syntax error //
// Error: moduleInfo -d -mn "£3¶%N–gD ‡Ø'q²ÐŠuÀ‹Y mÊóˆ 1£ò˜ &‚E†?`ÌVhÿU§G3 N.ü!¿ÕÆî› ³ ðÑW8M¢!a"; //
// Error: Line 1.49: Unterminated string. //
// Error: moduleInfo -d -mn "¹ ÐYîîË;È q縫©Î?X.¯ &( w7>~$n2ãÖ² ã4M[áåäÅ Üæ n‚ŪËǰáüQ @ "; //
// Error: Line 1.22: Unterminated string. //
// Error: Line 1.31: Syntax error //
// Error: moduleInfo -d -mn "ëÔ;.4URñ¯CÕj ÕúŽUë˜/ Ójwt{"; //
// Error: Line 1.31: Unterminated string. //
// Error: moduleInfo -d -mn "îU v+É|/k~<ìÅ ¶ÆãQl-xè Û¥¼‹Ù (ú¸p à×úü®¡¼Z/g¡$Ç"; //
// Error: Line 1.54: Unterminated string. //
// Error: moduleInfo -d -mn "þÂ%k-©"1 ÆIÉ2CÒï Æ ˆOg qAÒ¯4Î ¬=A*ÌÏ’®<i gÊ oýñ>Ò{ã‹gw/Ÿ”\!¾‹>$ Ñýƒ"; //
// Error: Line 1.28: Syntax error //
// Error: file: C:/Program Files/Autodesk/Maya2017/scripts/startup/autoLoadPlugin.mel line 32: Plug-in, "xgenMR", was not found on MAYA_PLUG_IN_PATH. //
// Error: file: C:/Program Files/Autodesk/Maya2017/scripts/startup/autoLoadPlugin.mel line 32: Plug-in, "BifrostMain", was not found on MAYA_PLUG_IN_PATH. //
# pymel.core : Updating pymel with pre-loaded plugins: mayaHIK, GamePipeline, CloudImportExport, tiffFloatReader, bifrostvisplugin, ikSpringSolver, ik2Bsolver, xgenToolkit, AbcExport, retargeterNodes, gameFbxExporter, VectorRender, OpenEXRLoader, lookdevKit, Unfold3D, Type, mayaCharacterization, modelingToolkit, MayaMuscle, rotateHelper, matrixNodes, AbcImport, deformerEvaluator, autoLoader, sceneAssembly, gpuCache, Substance, OneClick, shaderFXPlugin, bifrostshellnode, renderSetup, GPUBuiltInDeformer, ArubaTessellator, quatNodes, fbxmaya #
evalDeferred "shaderBallRendererMenuUpdate";
import arnold
// Successfully imported python module 'arnold' //
import mtoa
// Successfully imported python module 'mtoa' //
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
Maya 2017 importing module pymel 1.0.9 (C:\Program Files\Autodesk\Maya2017\Python\lib\site-packages\pymel\__init__.py)
// Successfully registered renderer 'arnold' //
// Warning: file: C:/Program Files/Autodesk/Maya2017/scripts/startup/autoLoadPlugin.mel line 32: Loading plug-in "mtoa" has resulted in changes to the scene that may need to be saved. //
updateRendererUI;
updateRendererUI;"
