Maya 2017 crashes everytime I open render settings for arnold
Arnold was working just fine before but since few days whenever I try to open render settings maya crashes without any warning. If I unload arnold from settings and preferences render settings opens just fine. please help
sean.heasley
Hi @Anonymous  and welcome to the community!
Is you Maya 2017 up to date? A quick test you can try is deleting your settings/preferences and then re enable the Arnold plugins.
Also, you may want to check and make sure that the Arnold version you are using is the most recent version.
Finally, what GPU are you using and does the driver version match our certified hardware list?
You can find our certified hardware list here!
Please let me know if anything changes!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
I tried deleting my settings/preferences and updated Arnold to it's most recent version but no changes.
sean.heasley
Hi @Anonymous
What about your GPU? Is the driver version the same as our certified hardware list?
Also, when you get the crash does it show an error report for you to fill out and submit to Autodesk?
If so, can you please submit it and let me know what the CER report number is?
sean.heasley
Hi @Anonymous
