Maya 2017 3D Paint tool not showing attribute to paint
Message 1 of 17
Haiii frnds,
i'm using maya 2017, I am facing a prblm that is, I can't assign/edit texture while doing 3D painting. and there is no option for attribute to paint( see the image)..pls help me
Hi @Anonymous your title '3D paint tool Problem' was edited for clarity by @sean.heasley
Replies (16)
Message 2 of 17
sean.heasley
Hi @Anonymous and welcome to the community!
Hmm this is unusual. When you get a chance, can you answer a few questions for me?
  • Do you have a texture applied already to the mesh?
  • What are you using for a material shader?
  • Are you on Update 4 for 2017? If not can you update to it and see if that helps?
Please let me know if anything changes!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 3 of 17
yes.. I already applied a texture ( vRay Shader)
Message 4 of 17
sean.heasley
Hi @Anonymous
I don't have access to vRay so I'm curious if that may be causing the issue.
When you get a chance, can you please try a standard Maya shader and see if the issue still occurs?
Let me know if anything changes!
Message 5 of 17
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did you get a chance to try the suggestion I provided yesterday? Did it help solve your issue?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 6 of 17
actually when I try with maya standard shader, it works... sorry for delay to reply... and thanks to ur reply
Message 7 of 17
thomaslisle1309
Hi I have teh same issue i have just re installed maya and I cant see anything under the attribute to paint     I have applied a lambert texture   any ideas what can be eth problem   cheers
thomas
Message 8 of 17
bairo736
I have the same problem here, and I can't find a solution. PLEASE HELP!
Here goes the message: // Error: file: C:/Program Files/Autodesk/Maya2020/scripts/others/art3dPaintCallback.mel line 2052: No paintable surfaces found. Have you set their shape nodes to be visible?
Thanks in advance.
Message 9 of 17
thomaslisle1309
Have you got a uv map?
Message 10 of 17
bairo736
Hi Thomas, I don't think so. But if that would be the case, where/how could I remove it?
Message 11 of 17
thomaslisle1309
Add a uv map under menu UV.
Try auto UV then you should be able to paint it
Message 12 of 17
bairo736
Already tried. But it doesn't work.
Message 13 of 17
thomaslisle1309
Just apply a lambert to a sphere polygon and you will see the dropdown box say colour it works
Message 14 of 17
bairo736
Sure, it works with any other mesh (sphere, plane, box, etc). But for some reason, it doesn't work anymore with the original sculpted mesh that I previously created.
Message 15 of 17
thomaslisle1309
Well something wrong with mesh. Make sure its got a uv map wont work without
Try checking mesh or retopology tool
Message 16 of 17
bairo736
Actually, I simply applied a new lambert to the mesh that I originally created (as you suggested for the sphere), and it perfectly worked. I still don't know why the mesh lost the first map I painted on it. But fortunately, this is smoothly running now. Thanks a lot for your kind support. Cheers!
Message 17 of 17
thomaslisle1309
kool
