Maya 2017/2018 wont launch in OS High Sierra 10.13.2
Message 1 of 61
So when i open Maya for the first time it works, no errors, nothing. But if i close and try re-open, maya launch with the splash art, and them crashes. No report message. I already checked my drivers, and did an clean uninstall, nothing. Please help.
Im on macbook pro 9,1
Ge Force GTX 650M
Replies (60)
Message 2 of 61
mspeer
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Message 3 of 61
sean.heasley
Hi @Anonymous and welcome to the community!
@mspeer made a good suggestion but I also wanted to get a bit more information.
Does Maya not open at all now or does it always open once and then crash if you close and try to re open it?
Please let me know if @mspeer's suggestion works or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 4 of 61
So, I reset my prefs folder, still got the same problem.
Message 5 of 61
Maya opens once when i turn on my mac, and crash if i close and try to re open.
The reset on the pref folder does not work unfortunately.
This time it gives me a crash report by apple
Message 6 of 61
sean.heasley
Hi @Anonymous
Do you see a Maya crash report when it crashes or only the apple report?
Also you may want to try a clean uninstall/reinstall of Maya.
Please let me know if anything changes!
Message 7 of 61
hi Sean, I can only see the apple report and already tried the clean uninstall, nothing changes.
Message 8 of 61
sean.heasley
Hi @Anonymous
So after opening it once it will crash when you try to re launch Maya.
Since its launching once normally we know that your machine can handle Maya but the fact that a clean uninstall/reinstall didn't help is quite unusual.
If you try to re launch it multiple times will it crash every time? If so, it's possible this may be an issue with your Mac hardware/software.
When you get a chance you may want to try contacting Apple support as well with the Apple error log you have.
Let me know if anything changes!
Message 9 of 61
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 10 of 61
Yes, crashes multiple times, i still have the same problem and im trying apple support.
Message 11 of 61
sean.heasley
Hi @Anonymous
Did Apple support help at all or are you still having this issue?
If your issue is solved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 12 of 61
Apple actually didnt give me support, so i still have the same issue.
Message 13 of 61
sean.heasley
Hi @Anonymous
Ah ok.
When Maya crashes on re-open, are there any error messages or logs? If so, can you please screenshot and post them here?
Message 14 of 61
The only message is the one that i attached here, sometimes appears and sometimes not.
Message 15 of 61
sean.heasley
Hi @Anonymous
There wasn't any attachment in your last post. If you're responding via email, attachments don't always go through so when you get a chance please come  back to this post and manually attach the error!
Message 16 of 61
Here is the error log i get :
Message 17 of 61
So, i decided to enter safe mode and try re-open maya to see if i get the same error, and it gives me an autodesk repor, here :
Message 18 of 61
sean.heasley
Hi @Anonymous
Ah that error log will help!
When it appears again, can you please fill it out and let me know either what the CER number is and/or what you used for an email address with the report?
This way I can look up the crash in our system and see what may be causing it!
Message 19 of 61
The CER is 163959992.
Message 20 of 61
mspeer
Hi!
@Anonymous , it's not advisable to make your email address public, please use private messages to share private data.
