Upon start up of Maya 2017 / 2018, I get this error message:
Fatal Error. Attempting to save in C:/Users/NameofUser/AppData/Local.Temp/name,20200901.2250.ma
I haven't changed anything recently and my drivers are all up to date.
I have tried a clean uninstall + install and the error still persists.
When I look into the crash report in notepad, this is what it says:
Exception code: C0000005: ACCESS_VIOLATION - illegal write at address 0x00000000
Fault address: 00000000 in C:\Program Files\Autodesk\Maya2017\bin\maya.exe
B3F7ED20:0000040B Logical offset (see .map file for location)
This error occurs if I open either Maya 2017 / 2018.
I have tried the editing of the maya.env files with:
MAYA_DISABLE_CIP=1
MAYA_DISABLE_OPENCL=1
Neither of which work and resolve my issue.
I have submitted several tickets via error reporting, the latest numbers are:
2017: CER_225658506
When I tried updating the service packs (2018), Maya works briefly for that session until I restart and then I am unable to open it again.
The ticket number after it crashed after working briefly: CER_225659061
My laptop details are the following:
Help, since I need to Maya as part of my job.
Hello @winnie.cheung,
thanks for your post! Can you please try the following:
Looking forward to your reply, if you had success!
Best regards,
Patrick
Hello @winnie.cheung ,
Just checking to see if your problem has been solved. Have you tried the above suggestions from @patrick.schock and did you have any success? If you find it helpful, please click on the "ACCEPT SOLUTION" button in his reply so this helps other users in the community find the solution too. Thanks!
