Maya 2017/2018 Crash on Start-Up, Unhandled Exception
winnie.cheung
Observer
Observer
winnie.cheung
Observer
Observer
Upon start up of Maya 2017 / 2018, I get this error message:
Fatal Error. Attempting to save in C:/Users/NameofUser/AppData/Local.Temp/name,20200901.2250.ma
I haven't changed anything recently and my drivers are all up to date.
I have tried a clean uninstall + install and the error still persists.
When I look into the crash report in notepad, this is what it says:
Exception code: C0000005: ACCESS_VIOLATION - illegal write at address 0x00000000
Fault address: 00000000 in C:\Program Files\Autodesk\Maya2017\bin\maya.exe
B3F7ED20:0000040B Logical offset (see .map file for location)
This error occurs if I open either Maya 2017 / 2018.
I have tried the editing of the maya.env files with:
MAYA_DISABLE_CIP=1
MAYA_DISABLE_OPENCL=1
Neither of which work and resolve my issue.
I have submitted several tickets via error reporting, the latest numbers are:
2017: CER_225658506
When I tried updating the service packs (2018), Maya works briefly for that session until I restart and then I am unable to open it again.
The ticket number after it crashed after working briefly: CER_225659061
My laptop details are the following:
  • OS: Windows 10 Pro 64 Bit
  • Graphics Card: Nvidia GeForce GTX 1650
  • Laptop: Dell XPS 15 7590
  • Processor: Intel (R) Core (TM) i9-9980HK CPU @ 2.40 GHz (16 CPUs), 8 Core(s)
  • Memory: 32 GB RAM
Help, since I need to Maya as part of my job.
patrick.schock
Autodesk Support
Autodesk Support
Hello @winnie.cheung,
thanks for your post! Can you please try the following:
  1. Please check, if the driver of the graphic card is updated to the latest version. You will find all drivers here: Download Drivers.
  2. Please check if the Intel Onboard Driver is active in addition to the installed graphic card and disable it in in case. This article shows how it works (it is about VRED but the procedure is the same for Maya or any other application): RT is greyed out in VRED Design and VRED Professional.
  3. If the steps from above do not help, create a new Windows user profile and start Maya from there: Create a local user or administrator account in Windows 10
Looking forward to your reply, if you had success!
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
lynn_zhang
Hello @winnie.cheung ,
Just checking to see if your problem has been solved. Have you tried the above suggestions from @patrick.schock and did you have any success? If you find it helpful, please click on the "ACCEPT SOLUTION" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
