Maya 2016 Student Version: Hypergraph Hiearchy panel is completely blank
Message 1 of 8
I've been starting to make my way through various YT tutorial series. For example: AutoDesk Maya 2016 Tutorials by Todd Palamar.
I've noticed a few ways in which my User Interface (UI) differed from his and in poking around, I was not able to resolve and get my UI to look identical to his:
(1) The Layout he is using seems to be have the Channel box / Layer Editor in some sort of "docked" or "embed" configuration to the right of his main panel as shown in the attaached screen cap of one of his videos:
Oyn0I
Whereas mine looks like this:
 T36on
(2) When he opens up his hypergraph hierarchy window
 Ax8_e
Whereas mine:
5fjEj
Completely blank
I'm guessing there are two possible explanations for the differences I'm seeing:
A. Student version just doesn't have all this functionality? or
B. I've got some default settings ticked somewhere that I should change?
Appreciate if anyone can clarify and--if (B) is the explanation--offer any suggested search terms that can put me on the path to learning how to troubleshoot these kinds of issues.
A related question: Given I have a student license which is now more than a year old (I believe it has at least a 6 months if not a year of valid duration  before it expires) and is of a version that is two versions "old," is it an option to "update" my student license to the latest version and thus avail myself of more up-to-date versions of the app.
As a side note: Maya is very cool. I'm glad I decided to tackle learning graphics production and start incorporating it into my auto-didactic learning routines. I've still a long way to go with C++ learning (nearing 2d vectors but still not quite there yet!), but I think that alternating between art learning and programming learning will actually be quite salutary at this stage.
Replies (7)
Message 2 of 8
Welcome to the community.
Did you a file a bug report so that this can get fixed as soon as possible?
Message 3 of 8
No, I didn't file a bug report yet, as I'm not clear whether anything is not working as intended.
As I said, it may be that (A( my student version simply lacks some functionalities which accounts for the differences, or it may be that (B) I simply need to change some default settings somewhere which would allow me to mimic the Youtuber's UI configuration.
(C) Bug (or to be more honest, incomplete install/incomplete update of my Maya 2016 student install) is another explanation, but I always assume user error first and only resort to "bug" as an explanation when all possible sources of user error have been eliminated Cat Indifferent
That is why I am asking, to clarify
Message 4 of 8
mspeer
Hi!
No need for a bug report.
It's for sure B).
1. What Service Pack do you currently have installed (maybe you need to install a later one)
2. Try a reset of your preferences.
Rename the folder prefs in folder 2016 to something like prefs_backup, or to reset everything, the folder 2016 to 2016_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Message 5 of 8
Thanks mspeer I will try those solutions!
Message 6 of 8
Yay! It worked. Thanks mspeer!
To summarize: I simply followed the directions at https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
For windows, and when I rebotted the app, my UI looks like the one in the YT videos.
Great stuff!
Message 7 of 8
Actually I spoke a little too rashly.
Regenerating the Prefs folder as the web page directed DID fix the UI configuration issues (my panels now look like the guys in the YT video).
But it did NOT fix the hypergraphic hierarchy view. When I open that, it remains blank.
Message 8 of 8
mspeer
Hi!
Some windows show content based on selection (in Viewport or Outliner).
Some nodes are hidden by default.
Hypergraph Hierarchy:
Options -> Display -> Shape Nodes
Options -> Display -> Hidden Nodes
Please read the Maya Online Help / Documentation for more details.
