Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya 2016 crashes on Start
8 REPLIES 8
Message 1 of 9
1218 Views, 8 Replies
Just recently, Maya 2016 keeps crashing as soon as I open it. When I click on the application only the Command window and Stack trace window pop up with a list of errors, then maya closes. I've tried downloading the new service pack and tried reinstalling maya alltogether but I am still having this problem. Is there any way to fix maya so it works again?
8 REPLIES 8
Message 2 of 9
Florian.Coenen
I have some questions:
1.: Is the issue since the first install? Or since when is the issue? What has happened before?
2.: Are you using 3rd party plugins that can cause that issue?
3.: Can you do a quick test and reset Maya by following this article:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
I hope that is helpful.
Florian Coenen
Message 3 of 9
in reply to: Florian.Coenen
1: This issue was not since the first install. Maya was working great up until two days ago. This has never happened before on my computer.
2: I'm not using any 3rd party plug ins. I've dowloaded everything from Autodesk.
3: Thanks for the article, I did the steps, however maya is still not working. Only the Command window and Stack trace are coming up again. I attached a picture of the command window code.
Message 4 of 9
fowlert
Do you happen to have any script files in your prefs in the "global" folder?  i.e. there are pref's that are specific to the version, in a folder with the version number, but then there is also a "scripts" folder that sits beside those that all versions of Maya can see.  You didn't copy a file into there did you?
Message 5 of 9
in reply to: fowlert
No, there aren't any scripts in any of the folders.
Message 6 of 9
I'm not sure if this would quite help, but here is what I am seeing in my command box:
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/startup/layerEditor.mel line 4330: Could not find attribute named "defaultRenderLayer.precompTemplate" //
// Error: line 86: Cannot find procedure "buildDefaultHotBoxMenu". //
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/muscle/cMuscle.mel line 519: menu: Object 'mainRigDeformationsMenu' not found. //
// AbcExport v1.0 using Alembic 1.5.4 (built May 9 2014 15:43:11)
// AbcImport v1.0 using Alembic 1.5.4 (built May 9 2014 15:43:11)
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/others/addSelectTypeItem.mel line 115: Cannot find procedure "updateSelectTypeItemState". //
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/startup/autoLoadPlugin.mel line 46: initializePlugin function failed (gpuCache) //
// Error: line 1: initializePlugin function failed (gpuCache) //
// BifrostMain plug-in loaded (built Feb 26 2015 18:00:13)
updateRendererUI;
// Error: file: /Applications/Autodesk/maya2016/plug-ins/xgen/scripts/muAddShelfButton.mel line 114: Object '' not found. //
// Error: line 1: The renderer mayaSoftware is not registered yet. //
// Error: toolButton -q -ann $gNonSacredToolWidget; //
// Error: Line 1.41: "$gNonSacredToolWidget" is an undeclared variable. //
Message 7 of 9
Service Pack 6 - crash.jpgThis is nearly identical to the issue I am having.....
Service Pack 6 seems to be the "update" causing the conflict.
Message 8 of 9
Thanks for the reply. I tried to update maya with the mac OSX service pack 6, but maya still isn't starting up.
Message 9 of 9
If I install service pack 5 for maya 2016, would the problem go away?
