I am trying to attach treads to a curve for an animation and the tread models are not aligning tot he curve properly.
What's going on here?
Solved by J450NP13. Go to Solution.
Magically it worked and the treads are aligned now. But I have encountered another issue.
When I grab the curve to parent it to the vehicles chassis and rotate the chassis the treads do this. How can I stop the treads from being affected by the rotation?
Brilliant! Thanks for sharing. I am wondering if it might also work if the source mesh is parented to the main parent body being rotated .
