Magic Track Pad 2 & Mac Desktop or MacBook Pro
My trackpad built into on my MacBook Pro accepts gesture input like it should. When I have my trackpad Magic 2 connected to my laptop, the cursor only zooms. I do not have any depressions on the the trackpad. Then when I connect my Magic trackpad to my desktop, I have the opposite issue. It constantly stays in tumble view. I am just gliding like I would to move my mouse around the screen. Is there a way I can prevent that from doing that? Or is maya only a three button mouse set-up? I really am used to gestures on my trackpad so would like to keep them. I like the trackpad option for my desktop unit.
I have attached a screenshot of settings per the autodesk article referenced below.
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Maya/fil...Screen Shot 2017-09-01 at 12.02.56 PM.png
sean.heasley
Hi @Anonymous and welcome to the community!
Generally it is a best practice to use a mouse and/or tablet pen that has 3 button functionality to avoid issues like this.
However for your issue there are commands 'Option+Command+Drag' that should allow you to pan or zoom instead of being stuck in tumble.
While I don't have a Magic Track Pad to test with, I found this video that will hopefully provide some assistance!
Let me know if it helps you out at all!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi!
I had seen that youtube video as well. It didn't work, either. I had commented on his video too. Your Command+Option+Drag helps for my built in trackpad on my MAC laptop so that is incredibly useful!! I did dig out my three button mouse. That works good. Bummer though for the external Magic Track Pad 2. As it really doesn't seem compatible. I still think it has potential, as gestures would be a cool way to interact with the program. I will un-bury out my Wacom tablet to see if that may have a more fluid feel for me.
sean.heasley
Glad the hot key command helped!
It is a shame that the tablet seems to have some issues with Maya however I can say personally I use a Wacom tablet with Maya and while it takes a bit of getting used to it works exactly how it should :)!
