lights and reflects in wrong positions after transfer project to other computer
Hi;
I created a scene on a computer and when transfer the project to my computer some lights and reflects are not on their positions:
this is the main one:
and this is what changed after transferring:
as you see there are some weird lights and reflection on the ceiling and floor.
what is wrong? are there any procedure I should to do for transferring a project?
Martin
sean.heasley
Hi @Anonymous
How did you go about transferring the project?
Did you move the entire project folder or did you export everything?
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi;
I moved the entire project.
also both graphic cards are Quadro 5000
mspeer
Hi!
Make sure to use the exact same Maya and renderer version on both systems with same Preferences in Maya, like Evaluation Mode.
Even better also use the same OS version + CPU.
The graphic card does only matter if you use a GPU renderer.
Please upload a scene-file (just a part of your scene like foreground object + lights).
sean.heasley
Hi @Anonymous
I'm just checking in to see if you need more help with this. Did the suggestion that @mspeer provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
