Issue with Maya 2019
I have done a brand new clean install of Maya 2019 on my Surface book 2 and when I start maya for the first time I get the following issue in my screen. (See photo). I can only get past this black squares when I click and drag over top of those black boxes, but as soon as I rotate the view or do anything the black boxes come back... Has anyone encountered this before and know of a fix?
Thanks.
sean.heasley
Hi @Anonymous
This is most likely a GPU issue. What GPU are you using and is the driver version the same as our certified hardware list?
You can find our certified hardware list here!
A quick test you can try as well is deleting your settings/preferences.
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided on Friday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi, Maya team I have done an update recently for Maya 2019.3.1 I have the student version don't but I'm facing an issue where when I update Maya for the new version it shows a black screen and here a picture of the issue.
Thank you in advance
Imad Ismail
