Is X_Ray Broken ?
Is X_Ray Broken ?
Message 2 of 13
Is X_Ray Broken ?
I turn on x-ray and everything is good, but as soon as I go to move a vertex, edge, x-ray kicks off. Is this broken or is it something Im doing?
[video]
Replies (12)
Message 1 of 13
I turn on x-ray and everything is good but as soon as I go to move a vertex, edge, x-ray kicks off. Is this broken or is it something Im doing?
[video]
Message 3 of 13
mspeer
Hi!
It works fine here (Maya 2017 update 4).
Please add more info:
- Maya Version?
- Viewport Version and Mode?
- Graphic Card Driver Version?
Message 4 of 13
john.paul.giancarlo
did you try to reset your preferences? your hotkeys shortcuts seem to be malfunctioning
Message 5 of 13
Hi! Thanks for the help!
@mspeerIm using the full Maya 2018. 2018 oddly enough has just one viewport which is the default. I have the latest driver from Nvidia us Geforce Experience.  I changed the material to a Blinn and it fixed. Although I started a new cube with default material and everything was ok.
@john.paul.giancarlo  I have remapped a lot of my hot keys and before I discovered that changing the material would fix it I did reset all my hot keys back to default and reset layout back to Maya Classic.
Maya did end up crashing a few hours later and even after a resart, I could not get Maya to do it again.
Message 6 of 13
john.paul.giancarlo
I am confused , is this issue fixed then or still the same ?
Message 7 of 13
sean.heasley
Hi @Anonymous
You may want to try deleting your settings/preferences.
I currently don't have this issue on my machine so hopefully its a simple fix.
Message 8 of 13
mspeer
Hi!
This is a duplicate, other thread here:
https://forums.autodesk.com/t5/maya-forum/is-x-ray-broken/td-p/7272856
Message 9 of 13
Yes I saw that duplicate thread I have no idea how that happened.  It happened to me again this morning at work. I changed the material out like last time and this time that didnt fix it. I really dont want to delete my preferences as for I have a lot of hotkeys I use. Speaking of hotkeys I think it has to do with the modeling toolkit. It seems to happen after I use hotkeys that are set to the connect tool or the target weld tool in the modeling toolkit. But that is just a guess at this point.
Message 10 of 13
sean.heasley
Hi @Anonymous
You can always back up your hotkeys/preferences before deleting them. Then you can see if a reset will help.
Message 11 of 13
sean.heasley
Hi @Anonymous just checking in, are you still having this issue?
Message 12 of 13
sean.heasley
Hi @Anonymous any changes with this issue?
Message 13 of 13
javad.farshbaf
Community Visitor
Community Visitor
Hi.
I have been this problem, and I could fix it by changing the material ( I used lambert).
Solved it.
