Is there a way to only view outline of the selected object instead of the whole wireframe?
ashutoshkbudhdeo
Message 1 of 12
ashutoshkbudhdeo
Basically the title. In Blender, the selected object only has an outline around it's silhouette which IMO makes it easier to see, so is there a way I can do it in Maya as right now it feels very cluttered? I can do a little bit of scripting too if required.
Thanks.
Replies (11)
Message 2 of 12
mspeer
Hi!
This is currently not possible.
You could change the transparency on the wireframe
https://help.autodesk.com/view/MAYAUL/2023/ENU/?guid=GUID-F7824D16-1342-4879-A669-3121D9D3582C
or disable the selection highlighting at all (per panel), but an outline for the selection is currently not an option in Maya.
Message 3 of 12
ashutoshkbudhdeo
Thanks for the reply.
Would it be possible to make a material that does this in the viewport, so that I can maybe write a script that switches to that material when an object is selected?
Message 4 of 12
shanemL33YK
Not sure if this is possible before maya 2023, but @sepu6 showed me an envvar that will make this work.
MAYA_VP2_SELECTION_INDICATOR=4
Message 5 of 12
ashutoshkbudhdeo
Hey thanks for the reply!
I don't know anything about environment variables but after reading the documentation I tried
putenv "MAYA_VP2_SELECTION_INDICATOR" "4"
in mel but it didn't seem to change anything.
Can you please explain how do I set this up?
Thanks!
Message 6 of 12
damaggio
Thanks guys, actually it worked quite well, it would be nice if this was implemented in Maya and maybe some additional options such as color and outline thickness options.  kudos @sepu6 .😁ObjectOutline.jpg
Message 7 of 12
shanemL33YK
You can not do it at runtime. You need to either set it globally before launching maya, or put it in your maya.env file located in
C:\Users\<USER>\Documents\maya\<VERSION>\Maya.env
You would want to add a new line to that file (if pre-existing content) and add:
Message 8 of 12
ashutoshkbudhdeo
It seems to be working, but now I am unable to see the edges/faces in the component mode and I have to toggle wireframe on shaded to view them, but I guess that's the limitation of this.
Thanks for the help!
Message 9 of 12
MRENOUX
hello, it works but how did you change the color and thickness of the outline? thanks
Message 10 of 12
ashutoshkbudhdeo
I had changed my selection colors from Windows -> Settings/Preferences -> Color Settings, and for the thickness of the outline, I think that's because I have anti-aliasing turned on in the viewport
Message 11 of 12
xc278260759
This feature is really useful, but it currently does not support USD. I hope the developers will improve this feature and add a switch inside Maya.
Message 12 of 12
mamorossi
Do you happen to remember which color setting controls the outline in the color preferences? I can't find it for the life of me.
