Is it possible to get facing ratio with xgen primitives?
tearcandy
tearcandy
Is it possible to get xgen primitives facing ratio in maya?
(I found this video!)
sean.heasley
Hi @tearcandy
I don't believe so since this tool is generally for shaders not for Xgen primitives.
That said, if you assign a shader to the primitives you may be able to get the facing ratio of that shader but not the Xgen itself.
Let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
Hi @tearcandy
Just wanted to check in to see how things were going. Did the information I provided yesterday help you at all?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
