Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Installing Maya on Ubuntu 20.04.6 LTS
17 REPLIES 17
Message 1 of 18
hokushin118
1520 Views, 17 Replies
Hello folks.
I am trying to install a trial version of Maya 2025 application on my Linux Ubuntu 20.04.6 LTS 64-bit machine,
using the Autodesk guidelines below:
Installing Maya 2025 on Ubuntu
I've successfully installed and registered it:
/opt/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper list
Licensing service is also up and running:
sudo systemctl status adsklicensing
When I run the following command to start the Maya app from terminal:
/usr/autodesk/maya2025/bin/maya
I get the pop-up window below:
But when I try to register the installed Maya app using my Autodesk ID I get the following error message in terminal:
Screenshot from 2024-09-11 15-44-25.png Here is content of the log file:
WebView2 is not found.
WebView2 is Microsoft library and is not currently supported on Linux. How can I fix it? Is it possible to install Maya (any available version) on Linux Ubuntu machines? Is there any workaround to bypass WebView2 requirement? Any help is appreciated.
Output of the gdb command:
cd /usr/autodesk/maya2025/bin
maya -d gdb
17 REPLIES 17
Message 2 of 18
nelsoncruz
in reply to: hokushin118
You will need to launch into a xorg session of gnome.  From the main log in, you should see a cog wheel or some other option on the display that will allow you to switch the current session.  You will need to pick one that says xorg. If none are available try following this guide.
https://askubuntu.com/questions/1428525/how-to-permanetely-disable-wayland
Nelson Cruz
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 3 of 18
hokushin118
Thanks a lot for prompt reply and further details. Appreciate it.
I disabled Wayland, rebooted laptop and tried to launch Maya again.
It didn't do the trick though... Continue to look for other options...
Message 4 of 18
nelsoncruz
Possibly changing/resetting the license mechanism.
Run the following command to check if Maya 2025 is listed at all in the output. If Maya 2025 is not listed than you need to register the product first.  If it is listed Maybe to a reset mayhelp.
sudo '/opt/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper'
Register:
sudo /opt/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register -pk 657Q1 -pv 2025.0.0.F -el EN_US -cf /var/opt/Autodesk/Adlm/Maya2025/MayaConfig.pit
Reset/Change registration
sudo /opt/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper change -pk 657Q1 -pv 2025.0.0.F -lm ""
Nelson Cruz
Message 5 of 18
hokushin118
in reply to: nelsoncruz
I did as you advised.
The problem still exists. I am attaching recent logs for your review.
Maya 2025 distos:
Message 6 of 18
nelsoncruz
assuming this guide was followed.
Installing Maya 2025 on Ubuntu (autodesk.com)
Nelson Cruz
Message 7 of 18
hokushin118
That's correct. I strictly followed the guide in question.
I use my Ubuntu machine for only coding java and python so IDEA, PyCharm, Docker Desktop and Telegram are the only third-party apps installed. All other apps come with Ubuntu 20.04.6 LTS preinstalled. Here are my gcc compiler and python versions.
I am also attaching the list of all packages I've installed on my machine.
Message 8 of 18
hokushin118
Today I tried to deploy the Maya 2025 on droplet on DigitalOcean cloud platform but failed. Please find below steps I took to achieve my goal. Migrating to a different Linux distro (certified by Maya) would be painful (laptop came with preinstalled Ubuntu 20.04 LTS x64, so drivers were compatible with hardware) so I want to avoid this step at all costs. Moreover, we are migrating our dev machines to the Debian based Linux distro (extremely similar to Ubuntu) at work, so it would also be better for me to stick to Ubuntu at home.
1. Created a droplet with Linux Ubuntu 20.04 LTS x64 OS on the DigitalOcean cloud platform.
2. Launched the droplet console as root.
3. Updated repos, installed RDP library and opened default RDP port of 3389 in UFW firewall for RDP connections.
sudo apt update && sudo apt upgrade
sudo apt install xrdp
sudo systemctl enable xrdp
sudo ufw allow 3389/tcp
sudo ufw enable
 4. Installed Ubuntu GUI, created a new user (hokushin) and added the user to the sudo group. Rebooted the system.
sudo apt-get install ubuntu-desktop
adduser hokushin
usermod -aG sudo hokushin
reboot
5. Connected to the droplet via Remmina RDP client (preinstalled on Ubuntu 20.04 LTS) as newly created user (hokushin):
6. Run terminal, disabled Wayland and rebooted the system:
sudo nano /etc/gdm3/custom.conf
# Uncommented
WaylandEnable=false
reboot
7. Strictly followed the Installing Maya 2025 on Ubuntu (autodesk.com) guide you gave me. Error is a bit different now - 3005 instead of 3070 but still exists. I wish there was a more detailed log. I am attaching screenshot for your review.
Output of the command below:
Message 9 of 18
nelsoncruz
I just went through the process on my end and can could not get the user license portion to work on my end either.  Maya 2024 seems to be registering and launching on the same machine so it looks like some mechanism has changed along the way.  I will ask a few others on my end but as of now I do not have a solution for Maya 2025.
Nelson Cruz
Message 10 of 18
nelsoncruz
To get passed the 3005 "SSO client" error. The Identity application also needs to be installed.  You will need to cd into the ./Packages/AdskIdentityManager
sudo alien -vc ./*.rpm
sudo apt-get install ./*.deb
after this install we are back to seeing the webview2 error.  I'll ask around on my end and try to get some answers.
Nelson Cruz
Message 11 of 18
hokushin118
Yes, same on my end. I've also started receiving the (3070) error message after installation the Identity application.Screenshot from 2024-09-16 18-57-05.png
2024-09-16 19:02:47: ERROR: Error Information: Maya 2025 : [IDSDK] 3070: The PC have not installed WebView2
WebView2 is not running on Linux yet... Looks like identity manager identifies Ubuntu OS as Windows...
I've marked the question as answered, but I wish that you'd included support to other Linux distros to the code in the future. For instance, "As is, no warranties" licence type for such scenarios is acceptable for me.
I appreciate your help in addressing the problem.
Message 12 of 18
hokushin118
Well, I’ve installed RHEL-9.4 WS over my Ubuntu 20.04 with dual boot.
Then i slightly adapted the guide for Ubuntu you gave me (Installing Maya 2025 on Ubuntu (autodesk.com)) to suit the RHEL 9.4 WS . As result, I could successfully install and launch Maya 2025 on RHEL 9.4 WS
Maya 2025 works as it is supposed to. But if you look at the terminal (I launched Maya 2025 from terminal) you'll see what kinda weird thing I have with my laptop's graphics card.
It doesn't affect the Maya 2025 functional capabilities but I am still very interested in finding out the real reason behind it. I am using NVIDIA graphics card:
I've doubled checked the NVIDIA driver installation guide but I am not sure what is wrong with my installation. What causes Maya return this error message on start up:
OpenCL evaluator failed to find OpenCL device with vendor Advanced Micro Devices, Inc..
If the problem is Maya 2025 related, any help is appreciated.
Message 13 of 18
hokushin118
Fixed the issue.
it was related to the NVIDIA GeForce MX350 graphics card driver configuration for X11.
Reinstalling NVIDIA driver did the trick.
Now it works as it is supposed to.🙂
Message 14 of 18
ostlerda
There is another thread that is exploring the installation of maya 2025 non-approved linux flavors here:
https://forums.autodesk.com/t5/maya-forum/can-t-login-with-autodesk-id-sso-on-linux/m-p/13051148#M10...
Still no solution but I thought I'd connect the threads as I believe it is the same webview2 issue.
Message 15 of 18
bugsdabunny
I've tried both AlmaLinux 9.4 and RockyLinux 9.4, the latter of which is listed as a supported distro. But both of them are giving the same WebView2 error. I am running on a supported platform and it is still not working. @nelsoncruz were you able to ask around about the WebView2 error and how to fix it?
Message 16 of 18
hokushin118
in reply to: bugsdabunny
Well, I’ve been working in RHEL-9 as my dev workstation for a couple of weeks now and I must confess that RHEL-9 really rocks. I use the free developer license and it suits my needs just fine. I like the platform. Maya 2025 also works fine on RHEL-9.
It took some time to optimize my current drivers to make sure they are working properly and compatible with my Dell laptop hardware. Once that is done, all that is left is to enjoy the power of real enterprise system.
Here is a useful link to the RHEL certified hardware.
I have not worked with AlmaLinux and RockyLinux distros before. But RHEL-9 and Ubuntu 20.04 doesn’t even compare. RHEL-9 is better.
Message 17 of 18
nouhad_waheed
Hi all i'm having the same error where nothing loads after I click on the sign-in button. Any updates on this?
Message 18 of 18
bugsdabunny
Unfortunately I cannot just switch to RHEL for several reasons. AlmaLinux and RockyLinux are supposed to be bug-for-bug clones of RHEL anyways, without the required license. I have used them both at studios and on personal machines before, RockyLinux is even listed as officially supported here: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-Requirement...
Maya 2024.2 also works on both distros, it is only 2025 that is not working, so my feeling is that this could be a bug on Autodesk's end
