Incorrect importation of the MetaHuman plugin to Maya
itaquee
New Member New Member
itaquee
New Member
New Member
Hello, Everyone. Could you help me about with the Metahuman to Maya plugin?
I got install MetaHuman Plugin in Maya 2024 from Unreal Engine 5.6, however I can’t import metahuman correctly, I don’t know why!?
It doesn’t exceed 8%, and when I “assemble” the mesh, it isn’t imported correctly, with no body and no rigging working.
I have some images with that problem. Has anyone else had the same problem?
itaquee
New Member
New Member
If you had the same problem, the solution is:
"Directory path with special characters
Your path is:
C:/Users/Fabiano Itaquê/Desktop/test
The ç and ê in your name may cause errors, as the plugin does not handle non-ASCII characters well. This has caused similar errors for other people."
