Incorrect importation of the MetaHuman plugin to Maya
itaquee
itaquee
Community Visitor
Community Visitor
Hello, Everyone. Could you help me about with the Metahuman to Maya plugin?
I got install MetaHuman Plugin in Maya 2024 from Unreal Engine 5.6, however I can’t import metahuman correctly, I don’t know why!?
It doesn’t exceed 8%, and when I “assemble” the mesh, it isn’t imported correctly, with no body and no rigging working.
I have some images with that problem. Has anyone else had the same problem?
itaquee
Community Visitor
Community Visitor
If you had the same problem, the solution is:
"Directory path with special characters
Your path is:
C:/Users/Fabiano Itaquê/Desktop/test
The ç and ê in your name may cause errors, as the plugin does not handle non-ASCII characters well. This has caused similar errors for other people."
