Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Importing .fmz and .step file into Maya
3 REPLIES 3
1840 Views, 3 Replies
I want to import a .fmz file and .step file into Maya but not sure how. Can someone help me out? I'd really appreciate it.
Thank you
3 REPLIES 3
sean.heasley
Hi @Anonymous and welcome to the community!
Maya used to use Direct Connect to import these file types but now Maya has ATF formats instead of Direct Connect like STEP_ATF for example.
Fmz files however I don't believe can be imported into Maya unless there's a 3rd party plug in that could handle this.
Please let me know if this information helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
sean.heasley
in reply to: sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided on Friday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi Sean,
I understand now. Thank you for your help!
Maya
