Image plane not appearing
ssommerv2
ssommerv2
recently been trying to put an image plane on my back view but it seems not to appear once I go on perspective view.  If anybody got any tips or can help thank you.
hamsterHamster
There, IP attributes should be visibility radio-switch between This View Only | In All Views
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
ssommerv2
Sorry, still new to Maya. Is there a way you can show an example on how to do that?
hamsterHamster
Sorry, was inexact in naming the switches. Select that imagePlane and go to its AttrEditor ctrl+a
,,,_°(O__O)°_,,,
ssommerv2
Oh okay. I already had that set already but still not seeing it.  It might be because it’s drag outside the perspective view.  Do you know how to drag the plane inside the view? I use the move tool but not getting any of the Axis showing up.
hamsterHamster
Can you try to find it in the same AttributeEditor, Placement section?
,,,_°(O__O)°_,,,
ssommerv2
Yes. I was able to find like the translation and scale section and able to bring forth the image. Thanks
