& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Im following a tutorial and hit a texture problem. My Image isnt visible in the UV Map and yes I'm in the object mode 😉 Someone told me to "a simple plane turn on the UV mode and shells and click on the uv window for planes its uvs are generally entire uv map space." but i dont quite understand 😕
Solved by sean.heasley. Go to Solution.
Hi @Anonymous
If you press the '6' key a few times while in the UV editor does the texture not appear?
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
I thought it might be better to add here another question instead of opening a new Thread..
well, I'm following the same tutorial but this time with a different butterfly model but I'm doing the same things and have different probs 😕
The left wing supposed to be at the left side and swing the same way as the right wing does but... it ended up at the right side so obviously I did something wrong but what?
Hi @Anonymous
Did you mirror the wing? If so you might have mirrored across the wrong axis which is why it stays in the same spot.
If that's not the case, please let me know what you did and/or if you have a link to the tutorial I could look at that would be really helpful!
All the best,
Sean Heasley
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
