Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
I would like to output scale animations that use Segment Scale Compensate to FBX and animate them correctly in Unity.
1 REPLY 1
takashi_endo
276 Views, 1 Reply
  • Assumption
    • There are thousands of target files
    • The parent-child structure of the joints cannot be changed.
  • Is there a way to remove the segment scale and export to fbx without affecting the movement and appearance of the animation?
1 REPLY 1
takashi_endo
in reply to: takashi_endo
Resolved.
I will share the solution.
- Create a multMatrix node
- Create a decomposeMatrix node
- Connect the source joint's attributes
- Connect joint.worldMatrix[0] >> multMatrix.matrixIn[0]
- Connect the attributes of the parent node of the joint of source
- parent joint.worldInverseMatrix[0] >> multMatrix.matrixIn[1]
- Connect multMatrix node to decomposeMatrix node
- multiMatrix.matrixSum >> decomposeMatrix.inputMatrix
- Connect a decomposeMatrix node to a target joint
- decomposeMatrix.outputScale >> joint.scale
- parent source to target Constraint
Translated with DeepL.com (free version)
