I had put my sweat and tears to creating a model for my project, and I remember for certain that I saved it. But I don' know where! And now I can't open it up. Please help me
Solved by sean.heasley. Go to Solution.
Hi @Anonymous
If you remember what you named the file as you can open the File Explorer and then type the file name into the search bar and windows should locate it.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
