Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
I can't creat a mask in xgen
2 REPLIES 2
Line_DreamWeaver
222 Views, 2 Replies
Hello!
I have a problem. If i want creat a mask in xgen interractive grooming this error message appears.
Error: file: C:/Program Files/Autodesk/Maya2024/plug-ins/xgen/scripts/xgmCreateAEUiForFloatAttr.mel line 171: No paintable surfaces found. Have you set their shape nodes to be visible?
I can't paint the mask on the model.
Do you have a solution ?
Thank you !
2 REPLIES 2
Is the surface visible?
Is a lambert shader on the surface?
https://linktr.ee/cg_oglu
Thank you !
I had texture map creat in substance.
I have creat new material lambert et it work. 🙂
