Hello!
I have a problem. If i want creat a mask in xgen interractive grooming this error message appears.
Error: file: C:/Program Files/Autodesk/Maya2024/plug-ins/xgen/scripts/xgmCreateAEUiForFloatAttr.mel line 171: No paintable surfaces found. Have you set their shape nodes to be visible?
I can't paint the mask on the model.
Do you have a solution ?
Thank you !
Solved by Christoph_Schaedl. Go to Solution.
Is the surface visible?
Is a lambert shader on the surface?
Thank you !
I had texture map creat in substance.
I have creat new material lambert et it work. 🙂
