How to turn off/toggle isolate select using keyboard
Isolate select is working fine when I hit Shift+I; however, it does wotk when I want to reverse this action (toggle) by hitting the same keys combination. Any suggestions? BTW, I am using Mac OSX (10.10).
Thanks in advance.
-K
Problem solved with this shortcut => Crtl+1
nicholas.zuccarello
Observer
Observer
I often get "// Error: line 1: model panel 'outlinerPanel1' does not exist" and then I have to use the menu to do isolate select. It works for me about 1/2 the time. 😞
Community Visitor
Community Visitor
There's an icon you can click in the menu of the view port. The box with the outline of a blue broken line with an arrow (to the right of x-ray), when you hover over it, it should say "isolate select".
