How to recreate this C4D material used in this biomedical animation tutorial?
Kranos_Orphydian
Advisor Advisor
Message 1 of 12
Kranos_Orphydian
he starts creating the material from 6:30 onward. Im mostly intrigued about what would be the counterpart of the Luminance channel of the C4D material system and the gradient  he is using within this channel to driven that glowing stripes sliding animation ("3D-Spherical" gradient). He also did some layering directlyin this Luminance channel (I kinda like how this works in cinema 4d ideal for motion graphics project). I suppose that can be done with the layered shader or Mix shader ?
https://www.youtube.com/watch?v=WQ4b0uBK-lA&t=1s
thanks in advance!
Replies (11)
Message 2 of 12
sean.heasley
Hi @Kranos_Orphydian
Generally this would be done by having a handful of textures/shaders set up and then key them at different values so they change during playback.
While it's not exactly what you're looking for, this is a short and sweet video that covers some basics to animating materials. You could use these steps and then apply masks or ramps so it moves across the mesh like in the video you shared!
Please let me know if this information is helpful or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 3 of 12
Kranos_Orphydian
well yeah I know we can animate  all these stuff but I wonder how to achieve the same effect.  I dont see something similar to that cinema 4d 3D gradient in the Maya ramp types (the circular ramp doesnt placed properly on my "cell" mesh like in the video. Also in cinema 4d you seem to be able to keyframe the whole gradient at once. Can we do that in maya without having to keyframe each color stop?
Message 4 of 12
sean.heasley
While I'm not 100% sure if you can key the entire gradient at once, there are ways with keying ramps to achieve the effect.
This video may help you out more since it specifically covers using ramps to work with animated textures.
Please let me know if this helps solve your issue or if you need any more assistance!
Message 5 of 12
sean.heasley
I'm just checking in again to see if you need any more information on animating shaders. Did the video I provided yesterday help you at all?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 6 of 12
Kranos_Orphydian
well I doubt you can find any decent tutorial on how to creatively animate shaders and ramps in Maya so no thnak you.. Otherwise I already checked all of these before.
Message 7 of 12
sean.heasley
That video I posted shows how to properly move and animate shaders and while they only show basic colors in the tutorial, you could substitute them with texture maps and alphas to mask parts of the texture and create the effect you're looking for.
I understand it may be a difficult process to simply recreate the effect in Maya but those videos should help you get started and have a fundamental beginning so you can tweak and change the effect to suit your needs.
If this still doesn't help solve your issue let me know and I'll see if I can find some more information and/or documentation to help you!
Message 8 of 12
mspeer
Hi!
There is no 3D Ramp inside Maya, so it will be a lot harder to achieve the same effect in Maya.
Help -> Speak Back -> Ideas for Maya
Message 9 of 12
Kranos_Orphydian
do you know  how to keyframe the entire gradient at once without having to key every selected color and selected position? I suppose thats not possible either
Message 10 of 12
mspeer
Hi!
These are separate Attributes if you want to control them at once you have to do some sort of grouping first.
You can use "Driven Key", "Scripting" and maybe "Custom Attribute" for easier control.
Message 11 of 12
Kranos_Orphydian
well like always, everything is more complicated in Maya. Thanks! Wish me luck in finding some resources to grasp all of these.
Message 12 of 12
mspeer
Hi!
It's the same as in Cinema 4D.
@Kranos_Orphydian
Maybe i understood you not correct. My suggestion where for a better control of multiple color values at once.
If you only want to set a key for all values at once, just set/add them to Keyable in the Channel Control of Channel Editor, then just with hitting hotkey "S" all values will be keyed at once.
