How to make sphere radius appear in attribute spreadsheet editor?
mail
mail
Just a quick question.
If I create a sphere, how do I get the radius to appear in the attribute spreadsheet editor? I can only get the main node properties, not the Sphere properties.
Hi @mail your title 'Attribute spreadsheet editor' was edited for clarity by @sean.heasley
Patrick Macdonald
Lighting TD
http://patrick.reformstudios.com
Developer of Mission Control , the spreadsheet editor for 3ds Max
http://mcontrol.reformstudios.com
sean.heasley
Hi @mail
After creating the sphere, if you click on 'polysphere1' in the Attribute Editor you should see it appear in the spreadsheet editor and the radius control should be the first option!
Please let me know if this helps solve your issue or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
mail
Ah thanks!
I had already tried that, but only from the attribute editor, not the
channel editor. Odd that the behaviour is not consistant!
Anyway, that's worked. Thanks!
Patrick Macdonald
Lighting TD
