hi;
I created a book but the problem is, when the book is open the pages didn't take the curve shape, how do I can fix it.
I mean how I can give them curve shape:
Martin
Hi @Anonymous
I would do this by having joints setup along the page of the book like in this video:
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
thank you Mr.sean;
it was new thing that I learned in this clip. thanks a lot.
but, I created the book with nCloth, the problem is in gutter of the paper. my pages gutter don't stay like this picture.
my book pages stay in flat shape and it damages the reality of physical shape of paper when a book is open.
I want my pages of book stay like what is in top image.
gratfully
Martin
Hi @Anonymous
Ah ok I misunderstood the issue. Have you checked your settings, gravity etc to make sure they aren't set incorrectly and causing this issue?
If you watch this quick video you can see that the paper sits normally and animates properly.
I think if you look at your model and tweak the nCloth settings etc you should be able to get a better result.
All the best,
Sean Heasley
