How to get UV Editor Toolbar back
Hoping someone is able to help.
New to this and unsure what I pressed but now, my UV Editor Toolbar is gone.
re: Image attached.  The image with the black is what I am seeing and the image with the white window is what it's supposed to be.
This isn't the menu that's gone; which I know you can get back by shift-M.
Also notice that my menu is missing the 'Polygons'..
Hoping this be an easy fix.
Thank you help for your replies.
faline.custodio.da.silva
@Anonymous
There have been significant changes to the UV Editor in Update 3.
Check this out: What's New in Modeling in Maya 2017 Update 3
But typically when the layout comes broken or customized beyond what you want to repair manually, you quickly reset the preferences to default:
Windows > Settings/Preferences > Preferences > Edit > Restore Default Settings
If that doesn't sort it out you can also reset your prefs folder: Reset Maya to default
If you have any other questions let  me know, happy to help! =]
Cheers
Faline Custodio Da Silva
@faline.custodio.da.silva
Hi Faline - thank you for your reply.
Oh no - I now realised that IS the patch 3 default menu - no wonder all my reset and everything did not work.
Haha, silli me.. why did they change it, the old MENU was a lot more easy to play with.
Thank you for your link to the change .. that really helped.  😃
@Anonymous
You're welcome! Have a great day!
Before Patch 3 was added to Maya 2017, I was able to numerically input precise UV values in boxes that used to appear in the old UV editor menu bar.   With 0.0 to 1.0 ranges I could assign values with a precision of 3 digits past the decimal point.  Where did it go???
gpmail1
Neither solution worked, I'm not surprised at all!
go to tools>show UV toolkit
