How to duplicate along a curve(circle)
mikhailkonstantin3d
mikhailkonstantin3d
Hello there .. i have found a tutorial that how to duplucate along .. its actually wasn't along curve .. was around a sphere ! I need to make a ring for marrige .. so you no i will use pipe then make a circle to duplicate the stones(stones) diamonds along it ! .. but is there a way to do it ? Like some way to attach the diamond to curve then starting adding more and offseting it until i see its good ??!!!
sean.heasley
Hi @mikhailkonstantin3d
There's a few ways you can do this.
One option, is to select an edge around the ring and go to Modify->Convert Poly Edge to Curve.
From there you can duplicate along that curve like in this tutorial:
[video]
Another option is to use MASH and the curve to duplicate around it like in this video:
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
infact it worked but not correctly
