How to delete old unwanted Missing Maya Plug ins?
Message 1 of 11
I opened an old rig file and it gave me errors like this ..  is there a way or a script to remove unwanted Plugins without trying to re-install all those missing ones?
Cheers!
Rosalie
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "vrayformaya", was not found on MAYA_PLUG_IN_PATH. #
requires "physx" "PhysxForMaya (2.86.00820.10150) , compiled 8/19/2012 1:03:57 AM";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "physx", was not found on MAYA_PLUG_IN_PATH. #
requires "maxwell" "1.6.4";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "maxwell", was not found on MAYA_PLUG_IN_PATH. #
requires "realflow" "5.0.2";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "realflow", was not found on MAYA_PLUG_IN_PATH. #
requires "finalRender" "1.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "finalRender", was not found on MAYA_PLUG_IN_PATH. #
requires "rpmaya" "2.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "rpmaya", was not found on MAYA_PLUG_IN_PATH. #
requires "faceMachine" "1.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "faceMachine", was not found on MAYA_PLUG_IN_PATH. #
requires "TurtleForMaya80" "4.0.0.6";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya80", was not found on MAYA_PLUG_IN_PATH. #
requires "TurtleForMaya70" "3.1.0.6";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya70", was not found on MAYA_PLUG_IN_PATH. #
requires "RenderMan_for_Maya" "1.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "RenderMan_for_Maya", was not found on MAYA_PLUG_IN_PATH. #
requires "MayaMan" "1.2.57";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "MayaMan", was not found on MAYA_PLUG_IN_PATH. #
requires "FurryBall_2012" "3.0.2208";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "FurryBall_2012", was not found on MAYA_PLUG_IN_PATH. #
requires "CraftMayaAdaptor2008" "7.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "CraftMayaAdaptor2008", was not found on MAYA_PLUG_IN_PATH. #
requires "mtorsubdiv" "1.1";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "mtorsubdiv", was not found on MAYA_PLUG_IN_PATH. #
requires "DisplaceD" "1.13";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "DisplaceD", was not found on MAYA_PLUG_IN_PATH. #
// Warning: line 0: Unrecognized node type for node 'shapeEditorManager'; preserving node information during this session. //
// Warning: line 0: Unrecognized node type for node 'poseInterpolatorManager'; preserving node information during this session. //
optionVar -sv colorManagementColorPickerColorSpaceSelection "Rendering Space";
optionVar -iv colorManagementColorPickerColorMgtEnabled 1;
// Warning: line 0: Errors have occurred while reading this scene that may result in data loss.
Please check the Script Editor for details. //
// File read in 62.2 seconds.
// Error: line 0: RuntimeError: file C:\Program Files\Autodesk\Maya2016\Python\lib\site-packages\pymel\core\__init__.py line 151: (kInvalidParameter): No element at given index //
// Warning: line 0: Python callback failed //
Replies (10)
Message 2 of 11
sean.heasley
Hi @Anonymous
It looks like the file is looking for plugins that may have been installed when working with the file and since it cant find them on your current set up it spits out the errors.
I don't know of a way to clear those errors but I would just ignore them as long as they aren't causing a problem with your file.
Message 3 of 11
Stephen.Blair
You have to remove the unknown nodes from the scene.
Google "maya remove unknown nodes",  you'll find a script
// Stephen Blair
// Arnold Renderer Support
Message 4 of 11
Hi Stephen, Thanks for your reply. I tried and followed the tutorial and it gave me this: it says like it requires specific nodes... I tried optimizing the scene by removing unknown nodes and it just says:
Removing unknown nodes
Optimize Scene Size Summary:
Removed 0 unknown nodes
________________________________________________________________________
file -f -options "v=0;" -ignoreVersion -typ "mayaBinary" -o "//alpha/ASSETS/CHAR_RIGS_PHONG/RS_ASIANWoman_R02.mb";addRecentFile("//alpha/ASSETS/CHAR_RIGS_PHONG/RS_ASIANWoman_R02.mb", "mayaBinary");
closeAllNodeEditors;
closeHypershade;
requires -dataType "byteArray" "Mayatomr" "2016.0 - 3.13.1.10 ";
requires -nodeType "RedshiftOptions" "redshift4maya" "2.6.31";
requires -nodeType "ilrOptionsNode" -nodeType "ilrUIOptionsNode" -nodeType "ilrBakeLayerManager" -nodeType "ilrBakeLayer" "Turtle" "2016.0.0";
requires "stereoCamera" "10.0";
requires "xfrog" "1.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "xfrog", was not found on MAYA_PLUG_IN_PATH. #
requires "vrayformaya2008" "1.0";
# Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "vrayformaya2008", was not found on MAYA_PLUG_IN_PATH. #
requires "vrayformaya" "2.20.01";
i cant think of another solution and Id really appreciate if you can give me more ideas to try..
Thanks again Stephen..
Cheers,
Rosalie Ocon
Message 5 of 11
Hi Sean,
Thanks for your note..  i think i wont have problems if i render it in our local farm but I'm not sure about if we outsource them to rendering companies outside... I checked the files were really old, and needs someone to clean them up otherwise errors will just gather... also, if we move to Maya 2019, it might make a mess?  those are the things im worried about.
Cheers,
Rosalie
Message 6 of 11
Stephen.Blair
Hi
Something like this should do it (although I did have to run it twice on one mental ray scene I downloaded)
string $unknownNodes[] = `ls -type "unknown"`;
for($node in $unknownNodes) {
    print( "Deleting " + $node + "\n" );
    lockNode -lock 0 $node;
    delete $node;
string $plugin;
string $unknownPlugins[] = `unknownPlugin -query -list`;
for ($plugin in $unknownPlugins)
    unknownPlugin -remove $plugin;
For just mental ray, this script works:
// Script to remove mental ray data from Maya scene files
// Run this script while the scene is open in Maya, then save the file with a new name
print("\n");
print("\n");
print("Working on:\n");
string $mrNodes[] = `ls -typ "unknown"`;
for ($each in $mrNodes){
	if (`objExists $each` && `unknownNode -q -p $each` == "Mayatomr"){
		print($each + "\n");
		delete $each;
if (`objExists mentalrayIblShape1`){
	delete mentalrayIblShape1;
unknownPlugin -remove "Mayatomr";
print "\n";
print "---> Done";
// Stephen Blair
Message 7 of 11
Hi Stephen!
This is awesome, Thank you! This solved the problem..
Best regards,
Rosalie 😄
Message 8 of 11
geniusyork
Observer
Observer
hello ,I have the same problem, but I used MAYA2014. The result is Error: line 10: Cannot find procedure "unknownPlugin". Can it be solved? Thank you。
Message 9 of 11
angelnacia
Works perfectly here, thanks Stephen!
Message 10 of 11
mnjlvrs
Hi Rosaile,
Use the script in Python tab.
Message 11 of 11
jjbbqq
Hi Stephen,
I think removing unknown nodes can only solve some of the errors, which has node type like below (attributes in .ma file):
requires -nodeType "vstExportNode" "PVstExportNode.py" "2.1.0";
But this method can't sovle errors like below. Because there are no nodes at all.
requires "vstUtils" "1.0";
