How to change Grid orientation? Y axis / X axis
Message 1 of 8
I have no idea how it changed, but my grid was set to the usual x/z orientation, but now it's changed to the Y axis, how do I change it back?, I googled this simple thing but oddly I found no solution 😕
As you can see, it's now set to the y axis, no idea what I pressed for this to happen
Replies (7)
Message 2 of 8
mspeer
Hi!
You can set this in:
Preferences -> Settings -> World Coordinate System -> Up axis:
Message 3 of 8
That was one of the first things I tried, it makes the camera controls go crazy inverted or something, and the grid still stays on the y axis
Message 4 of 8
mspeer
Hi!
Try in Viewport menu:
View -> Default View
What you also can try is:
a) Close Maya and reopen it.
b) Use Import instead of Open scene
Message 5 of 8
That did fix the controls for the camera but the grid still stays on the y axis, baffled
But i found if I tried the world up axis change on a different file, I can see the grid flip in real time, but not on this other file... I guess its a bugged out file?
[Other files work with the world axis change, but this particular file wont, seems its a buggy file, not maya itself, I moved my meshs to a new scene file and it works now, ill call this solved.]
Message 6 of 8
mspeer
Hi!
I can't say what's the problem with this particular file, but because of a scene-related issue I also suggested to try Import.
Message 7 of 8
yeah importing fixes the issue, but saving and then re-opening directly causes the same bug, weird
Message 8 of 8
mspeer
Hi!
Please provide a scene-file for further help,
everything else would just be guessing.
