Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How to change distance of a Pivot Manipulator Handles?
2 REPLIES 2
artur4EZV2
182 Views, 2 Replies
Hi there,
I managed to change manipulator handle distance form the centre. However I can't do the same for pivot manipulator.
You can see the difference in the clip. Also I'm showing my settings.
The clip should explain it better.
Shouldn't this just work?
2 REPLIES 2
brentmc
in reply to: artur4EZV2
Looks like the pivot manip will use the plane handle offset but only if the orientation handle is disabled. Otherwise it is being forced to 100%. (to avoid interfering with the rotate handle)
Brent McPherson
Principle Engineer
artur4EZV2
Indeed!
What a nonsense.
At least one can use middle mouse button to do the same.
Thanks for the reply!
Technology Administrators
