HI,
So if you ever copied your udims from one model to another via "Transfer attributes" you will also notice that there is an active link between both models.
I've learned that "deleting History" will break that link, however it also destroys all of my blend Shapes.
These blend shapes were created inside Zbrush (maya blend shapes).
So my workflow was:
Import blend shapes from Zbrush
Transfer udims to my blend shape model
Results are that the blend shapes are sluggish due to the Uv Linking.
If I delete History, I lose Blend Shapes.
Does anyone know of a work around to transfer udims to another model without active linking?
Thanks!
How does deleting of the Non-Deformer History, the next option under the regular one, works? Should keep the blendshapes.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
