Announcements
How to assign the same hotkey for two commands (press/release)
Hi. I created my custom hotkeys for Maya and I changed the soft selection press/release (B) for the repeat last command. However I want to return to the original B command (soft select press / release) but when I assign it to the Press one I cant use it on the release one because it says it's being used by another command.
How can I assign the "B" key for Press/Release commands? Thanks
brian.kramer
Make sure you click on the popup menu triangle to the right of the field. From that popup menu you'll need to select "On Press" or "On Release" as appropriate.
Brian Kramer
Software Developer
Thanks! That worked 🙂
