Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How do I fix a broken perspective camera?
5 REPLIES 5
rimcrazy
41091 Views, 5 Replies
I'm an instructor at a local CC.  One of my students was working with Maya 2016 on one of the lab machines and somehow managed to completely screw up the perspective camera.  It comes up zoomed out about a gazillion maya units out in space.  I go in, select the camera, null out the translations to the orgin.  I unhide the camera and by adding another camera I can see the perspective camera at the orgin.  As soon as the slightest move is made to zoom out the perspective camera it fly's out a gazillion maya units into space again.
I dumped the mel workspace for the project thinking that would fix it but not the case. Stop start Maya and create a new sceen and the camera is still messed up.  These are brand new iMac's BTW running Yosemite.
Any thoughts would be appreciated.
MacStudio M2
128Gb, 4Tb
Sonoma 14.6.1
MacDisplay, Dell U3415W
5 REPLIES 5
pshwayka
in reply to: rimcrazy
Have you tried using the predefined Perspective bookmark? View->Predefined Bookmarks->Perspective.
Otherwise, it may be easier to just delete the prefs folder and start again. If you're not familiar with where to find that on a Mac, look here.
rimcrazy
in reply to: pshwayka
No but I will look into that. I was thinking about deleting the prefs folder but I'm not sure I can do it on one of the school machines as I may not have write privileges on that folder. I did not try but I'll look into that when I get back to class on Thursday.
MacStudio M2
128Gb, 4Tb
Sonoma 14.6.1
magillaGuerilla
that solution is not correct, the camera is still broken whether you change the position manually or though a bookmark, as soon as it moves again it flies off into space.
mspeer
in reply to: magillaGuerilla
Hi!
Here is the solution:
https://forums.autodesk.com/t5/maya-forum/maya-scene-missing/m-p/7313983/highlight/true#M46033
and here with explanation why you can't correct this manual:
https://forums.autodesk.com/t5/maya-forum/persp-camera-nan/td-p/6510048
In short, you need to correct all Transformations (at once) and then correct Center Of Interest, without interruption.
It worked. Thanks for ur help!!!
