How can I fix this axis orientation problem?
I change the reverse of the object but it is back to normal
mspeer
Hi!
Try Modify -> Bake Pivot.
Also make sure in the Tool Settings the Axis Orientation is set to "Object".
Yes I try them but isn't working
brentmc
By default the custom axis orientation is a tool setting that will be reset when you change your selection.
If you want the custom axis change to persist then you need to use Modify > Bake Pivot.
Alternatively, Maya 2022 has a Bake Pivot Orientation setting in the transform tools which will auto bake the pivot orientation when you change it.
Brent
Brent McPherson
Principle Software Developer
mspeer
Hi!
In  contrast to the values shown in the screenshot of @brentmc  you need to set Axis Orientation to "Object" instead of "World".
This has to work, if not please provide a new video showing the new workflow and the settings you are using.
mspeer
Hi!
Any update on this?
I am pretty sure the offered solutions will work.
student_randa_azmy
Community Visitor
Community Visitor
