How can i drive / animate XGEN attributes ( density etc.) by expression
Hi all,
I searched  in forum and internet but could'nt find the way to do that.
im workin on hair animation with  XGEN  / Maya
i just want to learn how can i drive description attributes  -such as Density-  by expression or key
i can imagine that 🙂 ,
should be an array which include start frame and end frame information but i dont know how to write it with right syntax
so someone may show me the way how can i do that?
thank you so much for your helps.
cheers,
d.b.
sean.heasley
Hi @Anonymous and welcome to the community!
I'm a little confused by your issue.
Are you trying to change the density over time like keying it for animation or by scripting or something else?
When you get a chance, please come back and explain in more detail and I'll see what steps we can take to solve this!
Let me know if anything changes!
Hi Sean,
thanks a lot for your reply.
as you said, im tried to animate generic hair loss process using density map.
this was my first study with hair. i guess that's why i chose the hard way.
finally 🙂  , i solved my problem using Cut Modifier.   i used paint map as mask then animated it with Float expression.
cheers,
db
sean.heasley
Ah ok awesome job glad you solved it!
