Hey,
So I set up my hotkey set, and after a day or two the hotkey set file seems to get corrupted.
Anyone else experienced this?
I'm also syncing my user settings like shown in this video: https://www.youtube.com/watch?v=gqEpA-W8nBc , so I'm thinking that's what causing it to occure... but it does work on both computers until as said one or two days later. If it is however the cause, what other options is there for syncing my user settings?
Using Maya 2017, Windows10.
Solved by sean.heasley. Go to Solution.
Hi @Anonymous and welcome to the community!
I've never used the sync tools that were shown in the video but you may be right about that being the cause of the corruption.
I've always found its best to set up each machine I work on once and leave them alone after and/or keep a copy of the folder on a flashdrive or dropbox and manually download and place it on each machine.
When you get a chance, could you try not syncing the machines to see if your hotkeys dont get corrupted?
Let me know if anything changes!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Did some futher testing and it seems like my syncing method is the cause. After opening Maya 3-4 times on either computer is when the corruption took place.
Tried your method and it worked fine, files didn't get corrupted when manually transferring the folders like you said.
It's a bit of a hassle to update userprefs manually tho, an auto-sync feature would be awesome!
Hi @Anonymous
Glad it worked for you!
And you're right that would be a really cool feature! When you get a chance, you should make a post on the Maya Ideas Forum! This is a board regularly checked by our developers and they look to see what new features the community would like to see in new version of Maya!
All the best,
Sean Heasley
