Hello all,
So I am new to creating a low poly from a high poly model, I have seen various methods such duplicating the high poly, then removing all the edges manually, as well as quad draw. Both seem very time consuming, are these the only real process to creating a low poly from a high poly? Or are there better and easier alternatives to accomplish this process?
Thank you!
Every obejct is different. And therefore for each object there is a different workflow to get a fast lowpoly.
For hardsurface is the fastest way to create a proxy object (blockout) first. From this objet you create the low and the highres.
For sculpted objects its sometimes the same. You go from the (blockout) or create a new with retopo tools.
Sometimes the fastest way is to model a new low out of a box.
hi @Samsam2019
Thanks for posting! Did @Christoph_Schaedl's post sufficiently answer your questions? If so, please mark this thread as solved by hitting the 'Accept solution' button. This will help other forum members find their answers faster 🙂
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Not all questions have only one possible answer..
To reduce poly, would you not simply use the mesh/reduce option? Or the new retopology?
