Hi, First of I am not very active in this forum if this is posted in Wrong section do let me know.
So, I want to add some buttons in Channel Box in Rotation Section like "90" "180" "-" "+" like these ( Portrayed in Image) I am no coder but if anyone can assist me to code it, It be really helpful.
Solved by hamsterHamster. Go to Solution.
Can't you just hold J hotkey to toggle snapping? Go to Rotate Tool settings and set the snap angle.. for a long time I was using 22.5° setting, now I have it on 1°, experiment with what works best for you.
Please submit your UI suggestion to the Forum's Maya Ideas section.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the ACCEPT SOLUTION button, so others might find it much more easily.
I am aware of the J key and I know it may sound silly but for workflow speed up, I need some to create the Buttons or a sperate UI.
I believe you can do it yourself. You need to install Maya Bonus Tools for your version, and then look up for AttributeCollection..
,,,_°(O__O)°_,,,
