I've attached a scene, the problem I can't get Xgen hair to follow the guides in the scene, instead they are generated on the cube rather then the guides ?
Solved by santd. Go to Solution.
Hey there @Anonymous,
I opened the zipped file but it does not contain the XGen so I am not able to open it correctly on my end.
Could you either run a File > Archive scene and send me that zip or send me steps to replicate the issue from scratch.
Cheers,
Hello @Anonymous,
Unfortunately, the xgen file is not in that archive either. On your end there should be an xgen file that exists in the same folder where the scene file is being saved. If you send me that file, I should be able to open the scene file correctly and replicate what you are seeing on your end.
I am going to be closing the case that was automatically generated for this forum post, but I will be continuing to assist you through the forums.
Cheers,
Hello @Anonymous,
Thank you for sending me that. I was able to open your test scene correctly now.
I have created the attached Screencast video to show you how I was able to resolve the issue.
It looks like you were using attributes instead of guides to control the primitives.
Cheers,
