So since I have had 2014 installed grease pencil only worked once and I have not changed anything. It just worked all of a sudden one start up, but prior to that and since it has not worked at all. Everything opens (the menu) and when I add a frame and select a brush that all works, but when using the mouse or Wacom tab it will not paint anything. I even upgraded to the latest drivers for the Wacom, but like I said the mouse wont work either. Anyone have ideas?
I am not able to use the grease pencil suddenly now either. It doesn't draw anything in the viewport. It was working well for me for a long time. I just installed a big animation plug in this morning. Could it get broken by that? I just see this red circle move with my mouse or my wacom pen and it doesn't draw anything.
I have noticed that the grease pencil will also not work if your camera is parented under a scaled object. I often animate my camera in an empty group for a little extra control. If I scale the group it seems to break the grease pencil.
Hi there,
I also am having issues with grease pencil (maya 2014). I have tried messing with all of the above settings and no luck. If I try to use it this is the result I get in all viewports and with a mouse or with my tablet. Any ideas?
Hi. I'm having the same problem and still can't figure it out. In my case, small brush makes a bunch of pixelated dots.
I've checked camera option either, which has 0.100 Near Clip Scale and 10000 Far Clip Plane.. and have reset Maya setting several times.
Anyone has ideas?
Hi!
I have a problem with the grease tool too...
A box with tool settings suddenly disappeared. So I can choose grease pencil in a panel toolbar, but it is impossible to add or remove frame, choose another kind of pencil and so on....
How can I invoke the tool settings?
It could be opening off screen. If this is the case and you are using windows, you can click the grease pencil icon in your viewport panel. Without clicking anywhere else press "Windows key" + "Shift" and either left or right arrow keys.
This moves selected windows from screen to screen if you have multiple monitors. Maya doesn't seem to be very good at knowing when it's windows and panels are offscreen.
I had the same problem too. I fixed it in this way but I'm not sure it will work in every case.
1. I added grease pencil frame and made a few dots.
2. Go to greasePencilTexture1 tab in the Attribute Editor. Click on the incoming connection of Color attribute which opens greasePencilFile1 tab. Load any image in the Image Name box. The image should appear in your screen. Try the grease pencil again, it should work this time.
3. Delete the grease pencil frame from your timeline and create again. This time it should work without the background image in it.
Hey I too was searching for the same answer and I came to know that I had unselected GREASEPENCIL from the SHOW menu in viewport
In Viewport menu,Go to SHOW>select Greasepencil.
I hope it helps.
MANNN I can't believe this really works, I was having this trouble for so long. Haha, i love how is strange but very functional that is. THANKS!
I was just having this issue in 2018 and your solution worked!! Thank you!
