Graph editor bug - cant see the curves side maya 2022.1
scapollo
scapollo
I have a bug with the graph editor and I can`t work - it is non showing the animation curves. I only can see the left side part of the graph where the channels are. But there`s no way to arrange the graph and see the other part with the curves. I tried resetting the preferences, changing the workspace, nothing happens. There`s non arrow appearing on the left side that I can move to show the curves side.
Any idea?
arjanrr
Hi have you had any success with this? I'm dealing with the same error.
scapollo
no, I am sorry. I still have the same problem @kelly_hynes proposed me this solution
"Something similar was fixed in Maya 2022.   The workaround listed in the issue is:
If docked with another tab docked widget, it will display correctly. For instance, create a node editor, dock it, then create and dock the graph editor to the same location. Graph editor displays correctly. Close other docked widget, and Graph editor is still correct."
it is not working fr me, but maybe you`re more lucky 🙂
