where can I change the standard Film Gate settings?
I want to enhance them for having my used cameras in there.
I know I can make a preset and save it and reload this preset again.
I made this for the render settings it is set in the ImageFormats.mel and it is very confining to have it.
Thanks!
Hi @marlon_autodesk,
a way to build your custom camera presets would be to enter the "film" or "sensor" size in the Camera Attributes at Film Back > Camera Apperture. In my example I've setup a 6x7 film camera. Make sure that the Film Aspect Ratio of the camera matches with the Device Aspect Ratio in the render settings, to avoid a cropped image. You can save the camera preset in the upper right corner of the camera attributes.
Hope this helps!
Best regards,
Patrick
Hi Patrick,
I know this way with presets, but I fond it more elegant and easier to have my presets under this topdown menu like I set it for the render setting in the image size (second picture) which are stored in the file "imageFormats.mel" inside Maya.app/scripts/other (on Mac). Where I use just my common settings. So the list very short and customized for my needs. The question is, where are the film back defaults stored with are visible when using the topdown menu of Film back section.
