fbx exporting automatically turns off
I have maya 2020 and the fbx export option constantly turns off. I am able to manually go in and turn it back on, but the next time I open maya it does the same thing. I noticed other users have experienced the same problem with the same version, but no reponses on how to fix this issue.
Is there any way to let autodesk know so they can look into the issue? Perhaps its something related to the new version of maya.
Abdulla-Qaladzay
hi @Anonymous
make sure this option is checked in the preferences :
any time we want to we can save those changes manually
plug-in changes getting save with the preferences
P.P.S : there is options for UI changes depends to scene file as well
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting! Did you have a chance to try out @Abdulla-Qaladzay 's suggestion? Any luck?
If you have found a solution, we would love to hear about it and mark this thread as solved. Clicking the "Accept Solution" button helps other forum members find the answer faster.
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
yes it worked when I went into manually save the preference setting! Thank you guys!
