Fatal Error. Attempting to save in C:/Users/user/AppData/Local/Temp
Is there anyone out there to help me with this? I'm in way above my head with the fixes that I have read about.
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting! When does this error happen? During launch? Opening a file? 🙂 Any details would be very welcome!
To begin troubleshooting, I would recommend Resetting your Preferences to Default.
Thanks for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
It happens when I try to open up a project I was working on.
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for your reply 🙂 Please try Resetting your Preferences to Default.
Let us know how it goes!
Jordan Giboney
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Just wanted to check in and see how things were going 🙂 Did you have a chance to reset your preferences? If that solved the problem, you can mark this thread as resolved by clicking the "accept solution" button.
Thanks again for being a part of the forums! I look forward to hearing from you.
Jordan Giboney
I am having an issue getting a message while opening Maya
Fatal Error. Attempting to save in C:/Users/User/AppData/Local/Temp/User.20200627.0554.ma
could you help to solve this problem?
thanks
wisemansimeon
Hello, I have been having the same Issue as volavarri. When I try to open up a specific maya scene it will pop up with this error:
Fatal Error. Attempting to save in C:/Users/SIMEON~1/AppData/Local/Temp/Simeon Wiseman.20230703.0913.m
I have been having this problem for the past couple weeks, and I will randomly get this error. Sometimes the scene will open up with no problems but sometimes I cannot access it whatsoever. I have tried resetting my preferences, but it didn't work. It only made the error freeze my program, and I have to close it threw Task manager.
I have looked through multiple other forum posts and YT videos and they may solve the problem once, but then once I close and reopen the scene it gives me the exact same error.
I have attached my scene to this post, and a screenshot of the error when it pops up.
Thanks for your help.
